How to change the language displayed on an LCD Keypad.
  • How to change the language displayed on an LCD Keypad.
  • CraigEl
    CraigEl
  • AdamSteele
    AdamSteele
  • David_Kendrick
    David_Kendrick
‎2018-09-10 09:48 AM
Last Updated: Administrator CraigEl Administrator ‎2021-12-21 01:05 PM
Keypad installed in environment where the local language needs to be used instead of the default English.
EcoStruxure Security Expert.
Security Expert
SX-KLCS
Unsure how to change the language settings on the keypad.
You can change the language used by the keypad by setting the default language in controllers configuration. Go to Sites | Controllers, select the Configuration tab, and change the ‘Default Language’ dropdown.
One you have set your desired language and downloaded the changes to the controller, Users logging into a keypad connected to this controller will see messages in the selected language.
  • EcoStruxure Security Expert
Tags (2)
  • 19552
  • DavidKendrick21
