How often will an Automation Server ask the NTP server for the time?
  • How often will an Automation Server ask the NTP server for the time?
  • GavinHe
    GavinHe
  • Jonas_Brissman
    Jonas_Brissman
  • Benji
    Benji
  • Cody_Failinger
    Cody_Failinger
‎2018-09-11 10:22 AM
Last Updated: Sisko GavinHe Sisko ‎2022-10-04 02:22 AM
If the AS is configured to get the time from an NTP server the customer need to know how often the AS will ask the NTP server for the time.
  • EcoStruxure Building Operation Enterprise Central
  • EcoStruxure Building Operation Enterprise Server
  • EcoStruxure Building Operation Automation Server (AS/ASB/ASP)
In version 1.4, the AS asked the NTP server 1 time per minute. Starting in version 1.5, this was changed so the AS is using the standard solution for the NPT protocol.
When using the standard solution in the NTP protocol as the AS does starting in version 1.5, it depends on how much the AS drifts from the NTP server. The faster the AS drifts, the more frequently the time is updated.
For more information regarding Network Time, please see WebHelp article 6370 and corresponding articles.
Tags (3)
  • 16791
  • clock
  • GavinHeward22
100% helpful (1/1)
