HHC failure using Windows 7
  • HHC failure using Windows 7
  • sesa139513
    sesa139513
  • CraigEl
    CraigEl
‎2018-09-11 04:42 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 02:27 AM
Virtual Hand Held Controller on Windows 7 OS
TAC INET
I/NET site
Virtual HHC failure when using Windows 7 Operating System
Here is a work around for this issue.
After doing these steps it will very slow in updating. Only click once and wait, be patient it will work at some point with the HHC buttons.
NOTE: The above is unnecessary if using the "new" HHC that comes with 2.44 which also works on Windows 7 64-bit without changing any settings.
  • HHC Setting on Windows 7
  • Programming a 7798C controller with a Virtual HHC Console
  • Cable Connectivity to I/NET
  • TAC INET
  • 14008
