Cable Connectivity to I/NET
  • Cable Connectivity to I/NET
  • Cody_Failinger
    Cody_Failinger
  • sesa139513
    sesa139513
  • Jeff
    Jeff
  • Tom_Poovey
    Tom_Poovey
  • Roger_Bently
    Roger_Bently
  • Sacco
    Sacco
‎2018-09-10 02:40 AM
Communicating to I/NET on a direct connect requires a cable that has to be connected from the PC to the controller.
TAC INET
All versions of I/NET using Direct Connect to controllers.
Connecting to a controller from a PC if there are no Net Plus Routers for connectivity over the Ethernet. If a 7798C controller is being used then another programming cable needs to be used for the virtual HHC on that PC.
To resolve this a cable part number CBL-072 connected to the PC and controller. To obtain the various part numbers for the cables, connecting to the iPortal and searching on %CBL% should bring up the required information. Maximum supported cable length is 25 feet (7.62 meters). ***See the comment below on the CBL-072***
  1. Part number for the direct connect is CBL-072
    The pin-out for this cable is shown below:
  2. Part number for the 7798C is CBL-082
Note: CBL072 is for direct connect between the computer and controller. CBL-082 is for programming with Virtual HHC.
 ***The CBL-072 looks to be no longer available From Schneider Electric (9/2017) ***
You have two choices on the CBL-072:
1)            Build a new CBL-072 using the Pin-out above.
2)            Convert a CBL-082 into a CBL-072 (see steps below)
To convert a CBL-082 into a CBL-072, cut the “Gray” wire connected to pin 5 on the D-Sub 9 connector at the PC end.
Then remark the cable label to avoid future confusion on its use.
  • TAC INET
Tags (2)
  • 5588
  • inet
100% helpful (3/3)
