H909HV-S6 Current Transformer Does Not Change State
  • H909HV-S6 Current Transformer Does Not Change State
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-11 06:01 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-26 08:25 PM
The H909HV-S6 current transformer does not change state, even though current flow is present.
Andover Continuum, EcoStruxure Building Operation, Field Devices, Satchwell BAS & Sigma, Satchwell MicroNet
The issue is due to incorrect wiring between the current transformer and the DDC controller.
The installation instructions may appear to indicate that four connections are required to the DDC controller. However, this is not correct—only two connections are necessary.
To resolve the issue:
  1. Review the wiring diagram in the installation instructions carefully.
  2. Ensure that only two connections are made between the CT and the DDC controller:
    • The status output has two terminal sets, but only one connection is required from each set.
  3. Correct the wiring to match the proper configuration.
📄 Download the H909HV-S6 Datasheet
Labels (6)
  • EcoStruxure Building Expert
  • Field Devices
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
Tags (2)
  • 16254
  • CraigEllis25
