Guidelines for using large numbers in Access Control
  • Guidelines for using large numbers in Access Control
‎2018-09-06 11:03 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:43 AM
Are there any documented guidelines for using large number in Access Control?
TAC INET
I/NET Site
Begin by referencing TCON 300.
  1. All SLIs and DPUs must use I/NET Seven revision 1.x (or later) compatible binary software.
  2. All DPUs must have DIP switch 7 set to ON.
  3. Within a single tenant, you can assign a large key/card number directly to an individual, or translate the number using the Key/Card Translation table, but not both (i.e., you cannot have duplicate key/card numbers or individual numbers within a single tenant).
  4. Use compatible EPROMs in the DPUs Note: If you directly assign a key/card to an individual, and later translate the same key/card for another individual, only the translated key/card will be operational within I/NET.
  5. Other useful articles:
    • SCU dip switch 6 for dual station addressing
    • How to convert existing Idisc to large numbers (Hex)
    • DPU memory allotment in a 7910A and a Non-mipped 7920
  • TAC INET
Tags (2)
  • 1230
  • DavidKendrick22
