Get error "Local TAC Vista server not started . Cannot reserve graphic object" when trying to edit an OGC graphic from TAC Workstation
  • Get error "Local TAC Vista server not started . Cannot reserve graphic object" when trying to edit an OGC graphic from TAC Wo...
‎2018-09-07 04:12 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:42 AM
Get error "Local TAC Vista server not started . Cannot reserve graphic object" when trying to edit a OGC graphic from TAC Vista Workstation. Can not start OGC editor from within TAC Vista Workstation
TAC Vista
  • Windows Server 2008
  • Windows Server 2008R2
  • Windows 7
  • TAC Vista Server running as a Service
When using Windows 2008/7 the following legacy tools can not be used when TAC Vista Server runs as a service: TA Draw, TA Main, Database Generator, LIST.EXE, IPCL Editor, Test Client and UPGRFILE.EXE.
For more restrictions for Windows 2008 and Windows 2007 see the release TPA-VSTA-11-0002.01 for TAC Vista 5.1.5.
Run TAC Vista Server as an application.
Refer to Registering/Unregistering TAC Vista Server as a Windows service for registering/unregistering Vista Server as a service.
  • 4348
