Feenics Mercury Service stopped and Error code 13816 is shown
Select a Country
  • Feenics Mercury Service stopped and Error code 13816 is shown
  • RobertAndriolo
    RobertAndriolo
  • RandyDavis
    RandyDavis
  • JonGreen
    JonGreen
JonGreen Mentor
‎2018-12-19 07:01 AM
Last Updated: RandyDavis Champion ‎2020-04-23 11:16 AM
Unable to connect to Access Expert as the Feenics Mercury Service stops and will not restart after a system reboot.
Access Expert
Access Expert Premise Software (AX) v3
If the Mercury service is failing to start the most common issues are:
  1. Service Administrator password was changed
  2. Feenics API is not running
  3. The OS (Windows) may still be performing some background activity that might slow down essential system functionalities
Service Administrator password was changed:
  1. Update the password within these configuration files to match the new admin password
    1. c:\program files (x86)\feenics\web api\settings.conf
    2. c:\program files (x86)\feenics\mercury service\settings.conf
Feenics API not running:
  1. Check the API by opening the Internet Information Services and checking to make sure the Feenics website is running.
    1. Make sure the default site is not running.
  2. You can also check the bindings on the website
    1. Port 80 and binding of '*'
The OS (Windows) may still be performing some background activity that might slow down essential system functionalities:
  1. Open Windows Registry: Start -> Run -> regedit.exe
  2. File --> Export --> make a backup of the current registry
  3. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\
  5. call the new DWORD "AutoStartDelay"
  6. Set AutoStartDelay in milliseconds (decimal). E.G. 240000 is 240 seconds.
  • EcoStruxure Access Expert
  • JonGreen20
