Failed to Invoke the Security Expert Suprema Component
  • Failed to Invoke the Security Expert Suprema Component
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
  • Alan_Wood
    Alan_Wood
  • CraigEl
    CraigEl
Guinan AdamSteele Guinan
‎2019-03-26 10:20 PM
Last Updated: Administrator CraigEl Administrator ‎2024-01-22 03:20 PM
The error "Failed to Invoke the Security Expert Suprema Component" is seen when attempting to register/enroll a user's biometric credential at a Security Expert Client Only machine.
Figure 1 - Suprema scan errorFigure 1 - Suprema scan error
When doing a registration/enrollment from the Security Expert Server this error is not seen and the registration is successful.
EcoStruxure Security Expert
  • Security Expert
  • Suprema Biometric Reader
The Suprema.dll has not been properly registered on the local machine.
First check in C:\Program Files (x86)\Schneider Electric\Security Expert folder and confirm that the three files Suprema.dll, BS_SDK.dll, and BS_SDK_V2.dll are all present. If they are not you will need to copy them over from a working installation of Security Expert Server Installation.
Now run the below commands via an Administrator authenticated command prompt session:
For 64-bit machines
  1. cd C:\Windows\SysWOW64
  2. regsvr32.exe “C:\Program Files (x86)\Schneider Electric\Security Expert\Suprema.dll”
For 32-bit machines
  1. regsvr32.exe “C:\Program Files\Schneider Electric\Security Expert\Suprema.dll”
You should get a pop-up saying the .dll was registered successfully.
Close and re-open the Security Expert client and re-test enrolling a user's fingerprint.
  • EcoStruxure Security Expert
Tags (3)
  • AdamSteele19
  • AdamSteele24
  • AlanWood22
100% helpful (3/3)
