Error performing Continuum Database Initialization
  • Error performing Continuum Database Initialization
  • David_Kendrick
    David_Kendrick
  • Alan_Wood
    Alan_Wood
  • SangKim
    SangKim
‎2018-09-06 01:15 PM
Last Updated: Admiral David_Kendrick Admiral ‎2023-06-20 04:46 AM
When performing Continuum Database Initialization from a CyberStation workstation, the workstation cannot connect to the SQL Server with the following error message:
"Microsoft SQL Server Login Connection failed or server not available or access denied"
Andover Continuum
  • LAN workstations
  • Single User workstations
Possible Invalid Server Name is being used in Continuum Database Initialization:
  1. For Continuum LAN systems, the Server Name attribute of Continuum Continuum Database Initialization includes invalid characters.
  2. For Continuum Single User systems, the Server Name attribute of Continuum Continuum Database Initialization does not include the \SQLExpress attribute after the Computer name.
  1. For Continuum LAN systems, type the correct computer name of the SQL Server in the Server Name attribute field of Continuum Database Initialization screen such as "MyDBServer".
  2. Check that the required strong password is being used, such as "ABCabc123"
  3. For Continuum Single User systems, add the qualifier "\SQLExpress" at the end of the computer name in the Server Name attribute field of Continuum Database Initialization screen such as "MySUServer\SQLExpress" .
  4. Restart the SQL Server  Service and/or SQL Agent Service
  5. Check that the Windows Firewall on the Windows Server PC is turned off.
  6. Check Connection with sa Admin account on MS Management Studio and via ODBC.
Tags (2)
  • 6240
  • DavidKendrick23
100% helpful (1/1)
