Error during the SQL Configuration step for EBO WebReports (v1.8)
  • Error during the SQL Configuration step for EBO WebReports (v1.8)
  • David_Kendrick
    David_Kendrick
  • CraigEl
    CraigEl
  • Taylor_Leach
    Taylor_Leach
  • Derrick_Ratliff
    Derrick_Ratliff
  • Benji
    Benji
‎2018-09-11 11:52 AM
Last Updated: Sisko GavinHe Sisko ‎2023-04-25 07:11 AM
The following error is generated during the SQL Configuration step for 1.8 Reports Server
WebReports Installer
This can happen for various reasons:
Possible cause 1
The Microsoft .NET Framework installation is damaged after installing Microsoft SQL Server.
Possible cause 2
In one of the steps during SQL installation, we have to configure NT AUTHORITY\SYSTEM. If user fails to change this and move ahead with default user then create database step would fail.
Possible cause 3
The operating system is not using English as its selected language.
Solution 1
  1. Quit the WebReports Installer Package
  2. Remove/reinstall or repair .NET Framework 4.5 (Available from Microsoft .NET download site or direct download - WebInstaller - OfflineInstaller)
  3. Repeat the installation of WebReports
Solution 2
  1. Set the SQL server service log on properties to "Local System" (NT AUTHORITY\SYSTEM)MSSQLSERVER service.png
  2. Restart the SQL server service
Solution 3
  1. Replace the WebReports OS with an English version of Windows.
Tags (2)
  • 18838
  • DavidKendrick23
100% helpful (3/3)
