Error 404 displayed several times when connecting to an MPM
  • Error 404 displayed several times when connecting to an MPM
  • MaximeLaudren
    MaximeLaudren
  • CraigEl
    CraigEl
‎2018-09-11 02:37 PM
Last Updated: Lieutenant MaximeLaudren Lieutenant ‎2022-08-18 09:28 AM
The following error is displayed in the browser several times when connecting to an MPM
Not Found (Error 404)
DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">http-equiv="content-type" content="text/html;charset=utf-8">404 Not Found
After clicking through the errors the login page displays, however only English and French languages are selectable.
EcoStruxure Building Expert
SmartStruxure Lite Multi-Purpose Manager (MPM) Firmware revision 2.10 and later.
In versions of MPM firmware prior to 2.10, language support was provided by installing a languages.json file in the root of the MPM. This file when present causes the error in firmware 2.10 and later.
1. After login to the MPM select the File Manager tab and look for the languages.json file
2. Right click the languages.json file and select "Delete"
3. Logout of the MPM
4. No errors are displayed and the full selection of default languages are available.
  • EcoStruxure Building Expert
Tags (2)
  • 16297
  • MaximeLaudren22
0% helpful (0/1)
