EcoStruxure Building Operation WorkPlace Tech Editor Supported Microsoft Visio Versions
  • EcoStruxure Building Operation WorkPlace Tech Editor Supported Microsoft Visio Versions
  • RobertAndriolo
    RobertAndriolo
  • RyanSuar
    RyanSuar
  • RandyDavis
    RandyDavis
  • sesa139513
    sesa139513
  • Kim_Baze
    Kim_Baze
  • sesa116868
    sesa116868
‎2018-09-06 03:47 PM
Last Updated: Guinan RandyDavis Guinan ‎2024-12-18 10:23 AM
The following error context is encountered when trying to run WorkPlace Tech Editor to edit a program:
WorkPlace Tech Editor returned errorClass not registered 0x80040154 REGDB_E_CLASSNOTREG
EcoStruxure Building Operation, TAC I/A Series
  • I/A Series MNL, MNB Controllers (MNB - from SBO v1.8.1 and newer)
Only the 32-bit versions of Microsoft Visio is supported for use with WorkPlace Tech Editor. The error is seen when a 64-bit version of Microsoft Visio 2010 is installed.
Currently, only 32-bit versions of Microsoft Visio is supported for use with WorkPlace Tech Editor.
SBO 1.5, 1.6, 1.7 Microsoft Office Visio 2010 SP1, 2007 SP2, 2003
SBO 1.8 Microsoft Office Visio 2010 SP1 (32-bit), 2007 SP2, 2003
SBO 1.9, EBO 2.x, 3.x Microsoft Office Visio 2016 (32-bit), 2013 (32-bit), 2010 SP1 (32-bit)
EBO 2022 Microsoft Office Visio 2021 (32-bit), 2019 (32-bit), 2016 (32-bit), Microsoft Office Visio Plan 2 (32-bit)
EBO 2023 Microsoft Office Visio 2021 (32-bit), 2019 (32-bit), 2016 (32-bit), Microsoft Office Visio Plan 2 (32-bit)
EBO 2024 Microsoft Office Visio 2021 (32-bit), 2019 (32-bit), 2016 (32-bit), Microsoft Office Visio Plan 2 (32-bit)
Labels (2)
  • TAC IA Series
Tags (5)
  • 7950
  • RandyDavis22
  • RandyDavis23
  • RandyDavis24
  • RyanSuar19
100% helpful (4/4)
