EBO Cloud Connectivity Server Configurations
  • EBO Cloud Connectivity Server Configurations
  • JonGreen
    JonGreen
  • David_Purser
    David_Purser
  • JohnBoehmer
    JohnBoehmer
  • Katha
    Katha
  • RandyDavis
    RandyDavis
Commander JonGreen Commander
‎2021-11-19 01:44 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-06 06:08 PM
Encounter difficulties configuring EcoStruxure Building Operation (EBO) to connect with the Building Advisor Portal.
EcoStruxure Building Advisor
  • Building Operation Automation Server
  • Building Operation Enterprise Central
  • Building Operation Building Advisor
Multiple server configuration options exist for connecting to the Building Advisor Portal, each with distinct requirements and roles.
Below are the most common configurations and their requirements:
1. Stand-alone AS-P and AS-B SmartX Servers
Requirements:
  • EBO version 3.2.4 or higher
  • Servers connect directly to the EBO cloud
  • No intermediary server required
2. ES/AS Configuration
Requirements:
  • The Enterprise Server (ES) handles communication and data transfer with the Building Advisor cloud
  • ES acts on behalf of downstream SmartX servers
3. EC/ES/AS Configuration
Requirements:
  • All servers must run EBO version 3.2.4 or higher
  • The Enterprise Central (EC) communicates with the Building Advisor cloud only for itself
  • Cloud-connect settings are configured on EC and cloned to each ES
  • Each Enterprise Server (ES) manages communication for itself and its downstream SmartX servers
  • EcoStruxure Building Advisor
Tags (2)
  • JonGreen21
  • KatharineVasquez25
0% helpful (0/1)
