Does SmartStruxure Lite support e-mail servers that require authentication?
  • Does SmartStruxure Lite support e-mail servers that require authentication?
  • MaximeLaudren
    MaximeLaudren
  • CraigEl
    CraigEl
‎2018-09-06 10:04 AM
Last Updated: Lieutenant MaximeLaudren Lieutenant ‎2022-08-18 09:04 AM
Unsure what options are available in the Lua smtp.send() function.
EcoStruxure Building Expert
SmartStruxure Lite Multi-Purpose Manager (MPM)
The Lua smtp.send() function is not fully documented.
The syntax of the smtp.send() function is:
smtp.send
{ from = string, rcpt = string or string-table, source = LTN12 source, [server = string,] [user = string,] [password = string,] [port = number,] [domain = string] }
From above you can see that the "from", "rcpt" and "source" fields are required. Whilst "server", "user", "password", "port" and "domain" fields are optional.
Example Lua code is:
-- SSL email notification script example
-- Define the input you want to monitor below
var("temperature", "ME.AI1") -- Room Temperature
limit = 78 -- define the threshold
now = scl.sysclock()
if (temperature > limit) then -- When temperature is above threshold
    if (sent == nil) -- Check if e-mail was already sent
    and ((last == nil) or (now - last > 15 * 60)) then -- Maximum every 15 minutes
        sent = true -- Only send e-mail once
        last = now -- Keep track of last time
    result, reason = smtp.send {
    user = "alerts@server.com",  -- Enter your existing SMTP username
    password = "test1234",  -- Enter your existing SMTP password
    from = "alerts@company.com",  -- Enter your existing Source address
    rcpt = {
            "user1@company.com",  -- First recipient
            "user2@company.com",  -- Second recipient
            "user3@company.com"  -- Third recipient
    source = smtp.message( {
    headers = {
    from = "alerts@company.com",  -- Displayed source address
    to = "technicians@company.com",  -- Displayed recipients
    subject = "Temperature Alert"  -- E-mail title
    body = "Current temperature is: " .. temperature .. " (above " .. limit .. ")" .. " [" .. os.date() .. "]"}),
    server = "server.com" – enter your SMTP server
    if result ~= 1 then
        print(os.date(), "E-mail was NOT sent:", reason)
    else
        print(os.date(), "E-mail was successfully sent.")
    end
end
    else
    sent = nil -- Re-enable alerting on condition
end
Disclaimer: We hope that this script example and associated information (the
"information") is valuable to you. Your use of this information, however, is
at your sole risk. All information is provided "as -is", without any warranty,
whether express or implied, of its accuracy, completeness, fitness for a
particular purpose, title or non-infringement, and none of the third-party
products or information mentioned in the work are authored, recommended,
supported or guaranteed by Schneider Electric.. Further, Schneider Electric. shall
not be liable for any damages you may sustain by using/installing/modifying
this information, whether direct, indirect, special, incidental or
consequential, even if it has been advised of the possibility of such damages.
  • EcoStruxure Building Expert
Tags (2)
  • 14382
  • MaximeLaudren22
100% helpful (1/1)
