Differences between web.Client and CyberStation
  • Differences between web.Client and CyberStation
  • Ramaaly
    Ramaaly
  • Alan_Wood
    Alan_Wood
‎2018-09-10 04:41 AM
Last Updated: Administrator CraigEl Administrator ‎2023-04-03 05:45 PM
There are a number of difference between CyberStation and web.Client
Andover Continuum
  • Continuum CyberStation
  • Continuum web.Client Server
There are different features and abilities in web.Client and CyberStation and it's necessary to understand those differences.
The web.Client Planning and Installation Guide (Chapter 1) describes the main differences.
You generally use web.Client to view and monitor objects that were defined in CyberStation. The following table lists the levels of support offered with each major web.Client feature.
For information on web.Client features, see the web.Client online help.
LEVELS OF web.Client SUPPORT
Feature  View  Modify  Delete  Create
Personnel  X  X  X  X
Schedules and Calendars  X  X  X
Events within schedules only
Reports  X  X    X
Areas  X
Groups  X
Loops  X  X
Graphics  X
Alarms  X  X
Events  X
Distribution Events  X  X  X
Points and objects  X  X  X
Except: BACnet objects cannot be deleted.
TrendLogs  X  X
Video  X  1
Doors  X  X
Controller Web Pages  X
  1. Video can be modified, but not saved. For example, you can change cameras, show/hide time, change focus, zoom, but you will lose these changes if the page is refreshed or you open another editor.
 ** Graphics are slower through webpinpoint. Higher availability graphics may require a CyberStation.
Tags (2)
  • 6546
  • RamaAly23
