Determining the Version of a EcoStruxure Building Operation backup set from its .xbk file
  • Determining the Version of a EcoStruxure Building Operation backup set from its .xbk file
  • RobertAndriolo
    RobertAndriolo
  • David_Kendrick
    David_Kendrick
  • Cody_Failinger
    Cody_Failinger
  • AbeMeran
    AbeMeran
  • sesa145087_brid
    sesa145087_brid
‎2018-09-11 03:55 AM
Last Updated: Picard RobertAndriolo Picard ‎2023-05-10 07:27 PM
Building Operation Server backup set is incompatible for restore.
"Importing Backup Set"
"Backup set is of a different server type"
  • Automation server (AS)
  • Enterprise server (ES)
The backup set is for a different server type (version).
Determine the server type from the .xbk file to determine which server version will allow a restore.
The quickest method is to run the following tool SBO xbk Analyzer - Communities (se.com) and open the backup (xbk).  It will identify the
  • File name
  • Controller Type
  • Version / Serial Number
  • Time and type of backup.  i.e., Contents. Config only, Events and Trends, etc.
  • And much more.  See the link above or the Help topic on the tool for further information
Alternative methods are provided below:
The backup set contains information in the compressed .xbk file that can be retrieved this way ...
  1. Make a copy of the backup set as a precaution for safety reasons
  2. On the copy,
    • for AS change the file extension from .xbk to .zip.
    • For ES change to .tar
  3. Use a tool such as 7zip to decompress the file
Look for a file by the name x.x.x.xxxx.serverrevision (i.e. 1.3.0.4602.serverrevision)
This is the revision that the backup set was created at.
The Backup set can only be restored into a server running this revision.
Look for a file by the name xxxxxxxx-xxxxxx.backuptime
This is the date/time when the backup set was created.
Look for a file by the name Automation/Enterprise.servertype
This indicates whether the backup set is for AS or ES
Look for a file by the name xxxxxxxxxxxxx.servername
This is the name of the server when the backup set was created
Version 1.5 and above
There is a file by the name TDxxxxxxxxx.serverserialnr
This is the Serial Number of the server.
Tags (5)
  • 13337
  • DavidKendrick23
  • figure
  • out
  • RobertAndriolo23
80% helpful (4/5)
