DbCreate now displays the revision level and description of SQL in the Help About box
  • DbCreate now displays the revision level and description of SQL in the Help About box
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • Tom_Poovey
    Tom_Poovey
  • RobertAndriolo
    RobertAndriolo
‎2018-09-11 08:42 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 09:17 PM
How can I determine what version of SQL I/NET is using?
What version of SQL is installed on the I/NET PC?
TAC INET
I/NET Seven 2.10 and above
For previous versions of I/NET refer to How to determine the SQL version you are running with I/Net Seven.
To find out what version of SQL is installed and used by I/NET Seven site PC.
A new feature was introduced in I/NET Seven Revision 2.10 that allows you to view both the I/NET revision and SQL revision installed.  To view this all I/NET applications and the IO Server must be shutdown before performing the following steps:
  1. Start DBCreate >Start> All Programs> INet>DBCreate
  2. Login screen is shown, select either Windows login or enter the SQL Server Authentication details and click OK
  3. Right-click on the Title area shown in red below:
  4. After Right-clicking, select from the menu options About...
  5. The About DBCreate screen will then be shown and you can see both the I/NET Seven Version and SQL Versions as shown and highlight below:
For I/NET Revisions prior to 2.10 then refer to How to determine the SQL version you are running with I/Net Seven on how to view what version of SQL is installed.
  • TAC INET
  • 5313
This is a heading
