Created new bCX and can't see any of the system objects like system variables
  • Created new bCX and can't see any of the system objects like system variables
  • Alan_Wood
    Alan_Wood
  • BillNeville
    BillNeville
‎2018-09-06 01:30 PM
Last Updated: Administrator CraigEl Administrator ‎2025-08-29 03:11 AM
After creating a new bCX controller, system objects such as system variables are not visible.
Andover Continuum
  • CyberStation
  • bCX4040
  • ACX57xx
CyberStation did not fully create the new controller object in the database. This can occur due to a communication or initialization issue during the creation process.
To resolve the issue:
  1. Delete the newly created controller from the Continuum Explorer.
  2. Restart CyberStation to ensure all services are refreshed.
  3. Recreate the controller using the standard procedure.
Tip: Ensure that CyberStation is running with appropriate permissions and that the database connection is stable before recreating the controller.
Additional Notes:
If the problem persists after following the steps, verify the controller firmware version and compatibility with CyberStation.
Tags (2)
  • 5781
  • AlanWood25
