Configuration NCI's from a SE7000 controller are not visible in Vista
  • Configuration NCI's from a SE7000 controller are not visible in Vista
  • Ramaaly
    Ramaaly
  • PeterLarsen
    PeterLarsen
‎2018-09-06 10:01 AM
Last Updated: Lt. Commander Ramaaly Lt. Commander ‎2022-04-05 08:43 AM
When a SE7000 is setup in Vista you cannot configure the device using the nciCfg1FcuZn and nciCfg2FcuZn
EcoStruxure Building Operation, EcoStruxure Building Expert
  • Building Operation Workstation
  • Building Operation Automation Server
  • SSL SE7000
The configuration NCI's are not made available for Vista.
To edit these values the lonworks plugin can be used or the front keypad on the sensor itself.
Labels (2)
  • EcoStruxure Building Expert
Tags (2)
  • 14514
  • RamaAly22
