Clean db for Enterprise Server or Enterprise Central
  • Clean db for Enterprise Server or Enterprise Central
‎2018-09-06 03:26 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:38 AM
How does one get a clean database for the Enterprise Server or Enterprise Central?
  • Building Operation Enterprise Central
Warning
Need for clean database either for testing or start from scratch.
  1. Stop Enterprise Server or Enterprise Central using Software Administrator
  2. Go to the location of your database using Windows Explorer. In EBO V3.2 or higher, software administrator has a shortcut button for the databse folder. For this example it is C:/ProgramData/Schneider Electric EcoStruxure/Building Operation 2.0/Enterprise Server/db
  3. Delete the following folders if (some might not exist): Configuration, Historical, Persistent, System, UDT
  4. Start Enteprise Server or Enterprise Central using Software Administrator, the system will create a new folders and files as needed.
Note: Restoring a different database over the current database does not require the clean database state. Using the backup and restore procedure allows you to switch databases.
Tags (5)
  • 8108
  • blank
  • copy
  • fresh
  • MahmoudSayed23
100% helpful (5/5)
