Cannot open a PCT project when the computer running PCT has no connection to the network DHCP server
  • Cannot open a PCT project when the computer running PCT has no connection to the network DHCP server
  • StephenYang
    StephenYang
  • Jonas_Brissman
    Jonas_Brissman
  • CraigEl
    CraigEl
‎2018-09-10 08:52 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 09:47 PM
The Project Configuration Tool is installed as a Server. A project can be created but when it should be saved, an error says, "Failed to open project," and "Failed to start VM."
PCT version 1.1.1
When PCT is installed as a server PCT, and a project is opened, the computer running PCT must have a connection to the DHCP server in the network.
Make sure that the computer running PCT has a good connection to the DHCP server in the network.
Labels (2)
  • Project Configuration Tool
  • 19699
17% helpful (1/6)
