Can you mix HVAC and Security versions on the same system?
  • Can you mix HVAC and Security versions on the same system?
  • Cody_Failinger
    Cody_Failinger
  • sesa139513
    sesa139513
  • PaulFr
    PaulFr
  • RobertAndriolo
    RobertAndriolo
  • CraigEl
    CraigEl
‎2018-09-11 04:25 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 01:31 AM
When adding a workstation to be used for security can I use a SEC version of the software even though other workstations have Integrated (INT) security keys for HVAC parts of the system?
Andover Continuum
  • Continuum Workstation and Web Client all versions
  • Security Key
  • Dongle
Mixing Security key options on different workstations could have undesired effects.
It is not recommended to mix the security key options on different workstations, Continuum uses the Security levels to determine exactly what information a User can see or change.
So any system user should be able to log onto any workstation in the system and see the same information.
All Keys should also support the same I/O point count and Cyberstation version to operate correctly.
An exception to this may be the badging option -B that may only be required on certain workstations.
See What are the different options on the CyberStation security key? for a full list of options.
  • 13667
