Can Modbus TCP and Modbus Serial (EIA/TIA-485) be used on an AS together?
  • Can Modbus TCP and Modbus Serial (EIA/TIA-485) be used on an AS together?
  • PeterLarsen
    PeterLarsen
  • sesa125819
    sesa125819
‎2018-09-06 12:53 PM
Last Updated: Administrator CraigEl Administrator ‎2023-03-07 04:56 PM
Using Modbus TCP and Modbus Serial (EIA/TIA-485) on an AS together?
EcoStruxure Building Operation.
  • AS-P
  • Modbus TPC
  • Modbus Serial
Communicating with two third party devices simultaneously. Both are using the Modbus communication protocol. One is Modbus TCP, the other Modbus Serial (EIA/TIA-485).
Modbus TCP and Modbus Serial (EIA/TIA-485) can be used together on an AS-P. This configuration is supported and has been used many times.
Tags (2)
  • 6945
  • PeterLarsen23
100% helpful (1/1)
