Can I save Xenta memory using HFB's
  • Can I save Xenta memory using HFB's
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • PeterLarsen
    PeterLarsen
‎2018-09-10 03:40 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 05:45 PM
The Xenta controller has limited memory free and causing download issues.
Can I add existing Menta into HFB,s to free memory up?
TAC Vista
Xenta controllers 200, 300 and 400 series
The Menta application is too large for the controller
A HFB will actually use more memory than a application with no HFB's  with the same program.
See Menta Advanced Memory Usage: BPR Size Calculator for more information on memory description and allocation.
  • 6314
