Availability of I/A Series R2 and G3 objects for interface with the SE7000 Series Room Controllers
  • Availability of I/A Series R2 and G3 objects for interface with the SE7000 Series Room Controllers
  • Ramaaly
    Ramaaly
  • RandyDavis
    RandyDavis
  • WaynePeters
    WaynePeters
  • SESA113595
    SESA113595
‎2018-09-10 05:18 AM
Last Updated: Guinan RandyDavis Guinan ‎2022-04-05 09:51 AM
The client is inquiring about the availability of  I/A Series R2 and G3 objects for interface with the SE7000 Series Room Controllers
TAC IA Series, EcoStruxure Building Expert
  • I/A Series R2 UNC
  • I/A Series G3 ENC
  • SSL SE7000
Not able to locate shadow objects with matching LonWorks program IDs within the existing I/A Series R2 and G3 modules.
A set of new modules have been generated for use with the new SE7000 Series Room Controllers.  The new objects interface with the following program IDs.
R2 objects:
Se7273         (80:00:10:55:00:04:04:20)
Se76Pir         (80:00:10:55:00:04:04:21)
Se76RhPir    (80:00:10:55:00:04:04:22)
Click to download ... lonSchneider-2.301.330.zip
Click to download ... lonSchneider-2.301.431.zip
Click to download ... lonSchneider-2.301.534.zip
G3 objects:
Se72_73.lnml (80:00:10:55:00:04:04:20)
Se76Pir.lnml (80:00:10:55:00:04:04:21)
Se76RhPir.lnml (80:00:10:55:00:04:04:22)
Click to download ... lonSchneider-3.5.39.1.zip
Click to download ... lonSchneider-3.7.17.zip
The 3.5.39.1 module should be used with G3 versions 3.5 and lower.
The 3.7.17 module should be used with G3 versions 3.6 and higher.
Labels (3)
  • EcoStruxure Building Expert
  • Field Devices
  • TAC IA Series
Tags (4)
  • 6955
  • RamaAly22
  • RandyDavis22
  • viconics
