Automation Server I/O Modules firmware
  • Automation Server I/O Modules firmware
‎2018-09-11 09:23 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:33 AM
Experiencing issues with I/O modules that may include:
  • Backplane failure causing modules to assume wrong module ID
  • Input filtering problems on RTD modules
  • Stability due to electrical noise
  • StruxureWare Building Operation
The latest I/O module firmware version will correct known issues while also ensuring that the system is up to date and compliant.
The latest I/O module firmware can be located on the Exchange by searching for I/O Module firmware. Each firmware download zip file will contain a ReadMe file that explains what was corrected in that version.
Refer to Upgrading SmartStruxure IO Module Firmware for the procedure to upgrade the I/O module firmware.
Tags (2)
  • 16955
  • CraigEllis19
50% helpful (1/2)
