An error occurred while installing DSS: MSDTC 2
  • An error occurred while installing DSS: MSDTC 2
  • CraigEl
    CraigEl
  • sesa150555
    sesa150555
‎2018-09-07 01:33 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 12:12 AM
TAC Vista
  • DSS Installation
  • MSDTC
Users that get the following error message when installing Vista ‘Error occurred when installing DSS’ can be caused by the MSDTC (Distributed Transaction Coordinator) not being able to start.
In the service list Distributed Transaction Coordinator (MSDTC) is not started and it fails when you try to start it.
Check the windows event log. If you see the following error events logged in the Application log:
Event Type: Error
Event Source: MSDTC
Event Category: LOG
Event ID: 4163
Description: MS DTC log file not found. After ensuring that all Resource Managers
coordinated by MS DTC have no indoubt transactions, please run msdtc -resetlog to
create the log file. Event Type: Error Event Source: MSDTC Event Category: TM Event ID: 4185 Description: MS DTC Transaction Manager start failed. LogInit returned error 0x5.
Follow the steps in http://support.microsoft.com/kb/916926 to fix the problem.
For other possible causes for this problem see:
  • An error occurred while installing DSS: The account already exists
  • An error occurred while installing DSS:COM+ installation corrupt
  • An error occurred while installing DSS: Cannot Start Service
  • 2799
