Access Expert importing .CSV file SharingViolation_File Error
  • Access Expert importing .CSV file SharingViolation_File Error
  • Cody_Failinger
    Cody_Failinger
  • Alan_Wood
    Alan_Wood
‎2018-09-10 10:53 AM
Importing a .CSV file into Access Expert gives the following error:
Access Expert
.CSV File
During the import the Excel doc holds the file open and causes a sharing violation in Access Expert.
Close the Excel .CSV file during the import.
This will happen with the sample file from Access Expert or one created manually with the appropriate fields.
  • EcoStruxure Access Expert
Tags (3)
  • 19173
  • personnel
  • records
