Access Expert Lockdown
  • Access Expert Lockdown
  • Cody_Failinger
    Cody_Failinger
  • Roger_Bently
    Roger_Bently
‎2018-09-10 10:46 AM
Setting up a Lockdown Sequence in Access Expert
Access Expert
Windows 7, Windows 8, Windows 10
SQL2012, R2
SQL2014
Creating a Lockdown Schedule and it is not working because the Option in the Sys Settings need to be created first.
The following steps need to be followed to get this to work properly:
1. In Access Expert, create a Door Group called lockdown for the necessary Doors in Access Configuration
2. Open up the General Configuration, System Settings, User Interface tab and select the Door Group Dropdown Option
3. Select the Door Group from Step 1 and save it
4. Reboot the system for it to take effect and test the Lockdown procedure
  • EcoStruxure Access Expert
  • 19117
This is a heading
