20k (Honeywell) Thermistor does not work on an EcoStruxure IO Module
  • 20k (Honeywell) Thermistor does not work on an EcoStruxure IO Module
  • GavinHe
    GavinHe
  • CraigEl
    CraigEl
  • Cody_Failinger
    Cody_Failinger
‎2018-09-11 01:41 PM
Last Updated: Sisko GavinHe Sisko ‎2023-09-08 01:18 AM
When using the 20k (Honeywell) thermistor type on an EcoStruxure IO Module, the temperature value does not change and reads an inaccurate value.
  • Building Operation Workstation
  • Building Operation Automation Server IO Module
The 20k (Honeywell) thermistor type does not work properly in Automation Server IO module firmware versions 2.009 and older.
Check and upgrade the Automation Server IO module firmware to the latest version. Follow the steps below:
  1. Select the module in the System Tree (1) and on the Properties tab (2) check the Firmware version (3)
  2. If the firmware requires upgrading the latest version can be downloaded from The Exchange Download Centre.
  3. For instructions on how to upgrade the firmware see Upgrading Automation Server IO Module Firmware.
Tags (2)
  • 17218
  • GavinHeward23
