Error in PME2022 reports
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Error in PME2022 reports
Charles_Murison
Picard Charles_Murison Picard
525
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
EcoStruxure™ Power Monitoring Expert
Ricardo_RM
Lieutenant JG Ricardo_RM
Lieutenant JG
Posted: ‎2023-03-14 06:49 AM . Last Modified: ‎2023-03-14 06:52 AM
3251
I have a problem with some reports with a PME 2022, where when selecting them I get the error
"An unexpected error has occurred.
The request cannot be processed at this time. If the problem continues, contact the page administrator".
As can be seen in the attached image.
We already tried to create the report from scratch and still with the same error.
So, I wanted to ask if there is a solution for this error.
Thank you so much
@Charles_Murison @Attila_Fritz
  • Thumbnail of EcoStruxure™ Power Monitoring Expert
View products (1)
Mehran_Mehrnia
Admiral
Posted: ‎2025-02-20 08:09 AM
1
1699
Hi @willlee
I can see that this is a continuation of older posts in this forum. But, please note that this forum is dedicated to Metering & Power Quality. To get more assistance on PME, please post your question in the related forum.
Best Regards,
-Mehran
L3 Expert Advanced metering
Replies 4
Christian_Sáenz
Lieutenant JG Christian_Sáenz Lieutenant JG
Lieutenant JG
Posted: ‎2023-03-14 08:11 AM
Hi @Ricardo_RM,
I am attaching two similar cases, I suggest that we follow that same recommendation, I look forward to sharing the information with me to start the case.
https://community.se.com/t5/EcoStruxure-Power-Monitoring/Error-reports-PME-2021/m-p/376035
https://community.se.com/t5/EcoStruxure-Power-Monitoring/PME2021-web-reports-problem/m-p/361369
BR
CS
willlee
willlee
Cadet
Posted: ‎2025-02-19 05:09 PM
I have the same problem Ricardo, if you were able to solve it you can share it with me
Mehran_Mehrnia
Admiral
1
1700
Hi @willlee
Best Regards,
-Mehran
willlee
willlee
Cadet
Posted: ‎2025-02-20 08:41 AM
Hi @Mehran_Mehrnia,
Thanks for your reply, I tried to enter that forum but I don't have privileges to enter as you can see in the image. How do I get the privileges?
