Bigbatteries.com on Schneider 6848+
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Bigbatteries.com on Schneider 6848+
Charles_Murison
Picard Charles_Murison Picard
520
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
131
Ramasamy_N
Captain Ramasamy_N Captain
115
Robert_Lee
Admiral Robert_Lee Admiral
96
Posted: ‎2022-10-16 08:01 PM
1279
Hi. What are the steps and setup to replace 8 acid batteries (48/370ah) to a Bigbattery Cóndor Elite 48v?
https://bigbattery.com/products/48v-cndr-elite-lifepo4-231ah-11-8kwh/
I have two MPPT60/150 controller and 6848+ inverter.
Can i replace the batteries just turning all off, turn on and change charger and controller values using Lithium Ion menu?
Babajide
Ensign Babajide Ensign
Ensign
Posted: ‎2022-10-27 09:04 PM
seems like the settings would have to be adjusted. you can send a mail to babajide.ogunlesi@se.com so we can discuss further
Babajide
Ensign
Posted: ‎2022-10-22 03:10 AM
1228
For this, on the first step, it's as easy as swapping the batteries out from the connection of the MPPT cables and the inverter battery cables.
The second step would be to change the settings like you mentioned under the inverter (li-ion settings) and then under the MPPTs (custom battery settings) to match the battery specifications like voltage and currents specs amongst others
Posted: ‎2022-10-26 04:47 PM
1178
Thanks!
MPPT is working good. For any reason, battery is at 60% on the inverter 5 lights during the morning with no use (idle). Solar charge the battery for some mins and then start to sell.
Also I turned off the inverter charger due to Fault Code W49, DC Over Voltage.
Regards.
Babajide
Ensign
