82433members
349950posts
can I use PowerView for SUA1500VA?
liangyuan43_apc
125
This was originally posted on APC forums on 10/21/2009
I am using a SUA1500VA UPS for a backup power supply now, but the UPS was put in a pretty high place. I want to check the UPS without climbing up to a 15 feet high place.
Does PowerView, AP9215, work with SUA1500VA series? it seems in the AP9215's manual, it says it works with SU1500.
anyone has idea about it?
or any other solution?
Thanks,E
Sisko
Sisko
Re: can I use PowerView for SUA1500VA?
Yes, the AP9215 will work with an SUA1500.
4 Replies 4
liangyuan43_apc
another question, if I have many SUA1500VA UPS, can I just use one PowerView to inspect those UPS? just like the cable mounted on the UPS. once I want to inspect the UPS, I just plug the PowerView in.
Is that possible?
Sisko
Sisko
This was originally posted on APC forums on 10/22/2009
The PowerView is used only to communicate with 1 UPS. It has no capacity for interpreting multiple signals of any kind, and needs to be directly connected to your UPS.
Janeway
Janeway
You can use the PowerView to monitor one UPS at a time. You can unplug it from one UPS and put it on another one as needed.
Sisko
Sisko
