Posted: 2024-06-10 08:29 AM
Where to find UPS model and serial number with PCSS
Using PCPE, you could go to the following registry entry, HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\APC\PowerChute Personal Edition\3.1.0, select the TechnicalData node and obtain the model number and serial number of the device being monitored by the software.
Knowing that, I was able to create scripts to help maintain data in Excel about my fleet.
Can anyone tell me where PCSS keeps this same information, because I cannot find it?
Thanks!
Home & Office - UPS & Software
- Tags:
- english
Posted: 2024-12-13 11:42 AM . Last Modified: 2024-12-17 10:57 AM
Using the latest ChatGPT 4.o model, I have refined @BillP original code snippet:
# GetAPCDeviceInfo
# Obtain device Model and Serial number from the APC PCSS log
$computername = $env:computername
Write-Output "Current System '$computername'"
$location = "C:\Program Files\APC\PowerChute Serial Shutdown\agent\log\pcss.log"
$search4 = "Device detected!!"
# Read the log file and find the last line containing "Device detected!!"
$lastDetectedLine = Get-Content $location |
Where-Object { $_ -match $search4 } |
Select-Object -Last 1
# Regex pattern to capture the model number after "model:" and remove any trailing comma or spaces
$modelPattern = 'model:\s*([^,]+)' # This will capture the model number up to the first comma or space
# Regex pattern to capture the serial number after "serial num:" and remove any trailing comma or spaces
$serialPattern = 'serial num:\s*([^,]+)' # This will capture the serial number up to the first comma or space
# Check if the lastDetectedLine matches the model pattern
if ($lastDetectedLine -match $modelPattern) {
$modelNumber = $matches[1] # Extracted model number
Write-Output "The model number is: $modelNumber"
} else {
Write-Output "Model number not found."
# Check if the lastDetectedLine matches the serial pattern
if ($lastDetectedLine -match $serialPattern) {
$serialNumber = $matches[1] # Extracted serial number
Write-Output "The serial number is: $serialNumber"
} else {
Write-Output "Serial number not found."
Hope that helps someone!
Posted: 2024-06-12 05:25 AM
You can query the pcss.log file for the information using PowerShell.
Run the command
Select-String -Path C:"\Program Files\APC\PowerChute Serial Shutdown\agent\log\pcss.log" -pattern 'Back-UPS' (The command is entered assuming PowerChute has been installed to the default path.)
You will also find the information in the About.
Posted: 2024-06-12 11:34 AM
@BillP - This sample is significant help. Of course I'm going to have to change all of my existing scripts, but...
I'm going to suggest that the -pattern value should be 'Device detected!!' because not everyone will be using a Back-UPS device.
Also, I changed your sample to the following:
This will get the last entry in the log file with the most current serial number.
# GetAPCDeviceInfo
} else {
} else {
