SRT1500RMXLA doesn´t recognize the SMX48RMBP2V external battery pack
  • SRT1500RMXLA doesn´t recognize the SMX48RMBP2V external battery pack
2151
121
robmir_apc
Lieutenant robmir_apc
Lieutenant
Posted: ‎2024-07-13 05:09 AM . Last Modified: ‎2024-07-13 06:20 AM
679
Hi Bill and hope you are fine: this question is for you !!!!!   Since my wife´s MacMini after it´s  latest firmware update doesn´t like the threshold of our SMX1000 when switching from A/C to battery and turns off right away   I bought a dual conversion SRT1500RMXLA to replace it and was expecting to hook to it the 3 SMX48RMBP2V external battery I had hooked to the older SMX1000 since this double conversion UPS has the same type off 48 Volt blue 4 pin conector  and unfortunately this UPS doesn´t recognize them.
I was checking the recommended SRT48RMBP and believed you only designed it to use the same type of battery cartridge as the SRT1500 but it seems you also changed something on the external battery sensing logic.
Is there a way as to trick the SRT1500 to recognize the  SMX external  battery packs series ?
By the way which is the SRT1500RMXLA front bezel  replacement part number ? The screen display is bigger so an SMX bezel doesn´t fit at all !!!
  • Home & Office - UPS & Software
Kirk
Posted: ‎2024-10-15 05:12 AM . Last Modified: ‎2024-10-15 05:14 AM
669
I swear this exact question was posed and answered by me this year?!? 🤔
Regardless, the SMX Series uses a simple resistor network to inform the system how many extended battery packs are present.
The SRT Series uses a combination of resistor and a IC to determine if an extended battery pack is present, serial firmware, temperature, battery health etc.
The SRT Front Bezel: 0M-77876
Guess you made a duplicate post:
https://community.se.com/t5/APC-UPS-for-Home-and-Office-Forum/SRT1500-Doesn-t-recognize-external-SMX...
robmir_apc
Lieutenant
Posted: ‎2024-10-16 03:08 AM
In response to Teken
644
Thanks, I got you the first time so I don´t understand why the question was duplicated đꤔ
Kirk
Posted: ‎2024-10-16 03:14 AM
In response to robmir_apc
Probably a glitch in the Matrix 🤣
