Replacing the battery in UPS BE-850
Showing results forΒ
Did you mean:Β
  • Replacing the battery in UPS BE-850
2151
Spock Teken
110
83
UpsMetalMania
UpsMetalMania
Cadet
Posted: β€Ž2025-08-25 09:22 AM
113
I have just replaced a batter in a UPS BE-850 it seems it came already charged. Do I still need to leave the UPS without anything connected for 24 hrs? Thank you!
  • Home & Office - UPS & Software
Spock Teken
Spock
Posted: β€Ž2025-08-26 01:51 AM
Anytime the internal (RBC) Replacement Battery Cartridge is replaced the following steps and procedures must be followed to insure the best performance and operations.
Battery: The battery should be allowed to charge for at least 24 hours. The battery installation date must be updated via Power Chute (PCSS / PCPE) if available.
As doing so will reset internal counters and adjust charging tables if applicable.
Self Test: Manually initiate a self test and let pass. Allow the RBC to recover back to 100% SOC (State of Charge).
Calibration: Manually initiate a battery calibration via PCSS / PCPE. Ensure there is at least 30% attached load to the outputs. Once complete allow the RBC to recharge back to 100% SOC. Doing this procedure will insure the operational runtime is as accurate as possible in PCSS / PCPE.
NOTE: Mark down the battery installation date onto the RBC with a sharpie.
Questions Ask . . . πŸ‘
UpsMetalMania
UpsMetalMania
Cadet
Posted: β€Ž2025-08-26 06:54 AM
@BillP Do you agree ? Thank you!
Β
