H15 Power conditioner "Wiring OK" LED fix
Send InviteCancel
Posted: 2025-03-1811:10 AM
A while back there was an issue with the H15 power conditioner where the "Wiring OK" LED indicator would not illuminate when the supply was wired properly. At the time units were replaced under warranty.
I have two of these and would like to repair them.
Has the fix been published?
I assume the fix is board level component replacement.
Is it possible to point me to the fix if published or to check the Engineering archive for the fix and share it?
