Continue
  • My Subscriptions
  • Events
BackUPS XS Series BX1300LCD displaying battery disconnected error
  • Exact phrase โ†’ Use quotes " " (e.g., "error 404")
  • Wildcard โ†’ Use * for partial words (e.g., build*, *tion)
  • AND / OR โ†’ Combine keywords (e.g., login AND error, login OR signโ€‘in)
  • Keep it short โ†’ Use 2โ€“3 relevant words , not full sentences
  • Filters โ†’ Narrow results by section (Knowledge Base, Users, Products)
Showing results forย
Did you mean:ย
  • Re: BackUPS XS Series BX1300LCD displaying battery disconnected error
BillP Leader
2151
Teken
Teken
154
Techie_apc
Techie_apc
83
Anonymous user
Not applicable
Posted: โ€Ž2021-06-29 03:32 AM . Last Modified: โ€Ž2024-03-22 01:24 AM
1862
I've had my BackUPS XS Series BX1300LCD for a number of years without any problems. This system covers both a small file server and Dish SAT box. Tonight I noticed an error stating the battery in your battery backup is disconnected. I've pulled the batteries and check the connection as well as performing a full power down of the device. At times it will display the capacity on the unit, but most the time it shows no batteries detected. I've pulled power to simulate a power failure and it does still work and show time remaining, but as soon as it is connected back to AC it shows the same error.
I have 4 different UPS's and have replaced batteries many times, but in this instance I'm reluctant to put $60 dollars back into the unit is the failure is not battery related.
Specs:
Serial number: JB0652014018
Firmware revision: 836.H4 .D
Software version: PowerChute Personal Edition 2.0
Thoughts?
VG
  • Back-UPS & Surge Protectors
Anonymous user
Not applicable
Specs:
Thoughts?
VG
Replies 5
Anonymous user
Not applicable
Thanks for the response JonPro. I do have a 3 month old 1300LCD and that is my next step. Strange thing is it shows capacity about 25% of the time with a good valid run time. I'll swap out the batteries at my next reboot and post back. I was just curious if this was a standard failure others were seeing or something strange where I shouldn't waste my time. ๐Ÿ˜‰
VG
BillP Leader
Leader
VG,
You are welcome. I hope we can hear from you soon about the outcome. Typically, whenever a UPS shows flashing replace battery LED or disconnected battery it means that the battery has not been connected yet. If it is connected and you have tried reseating the connectors/ cables and it still shows the same thing even after swapping with a known good battery the issues lies with the UPS.
JonPro
Anonymous user
Not applicable
Update to my post: I ordered a new battery from Amazon and it fixed me right up. While I was at it I went ahead and bought a new high capacity for my my really old 650 and put it back on duty again.
Thanks for the help.
VG
BillP Leader
Leader
VG,
You are very much welcome. Thank you for using the APC Forums
JonPro
Anonymous user
Not applicable
Specs:
Thoughts?
VG
ย
Youโ€™ve reached the end of your document
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
