Back-UPS Pro 900 end noise?
  • Back-UPS Pro 900 end noise?
2150
127
Posted: ‎2021-06-29 07:38 AM . Last Modified: ‎2024-03-21 04:47 AM
1102
I have buy a Back-UPS pro 900 but when i turn it on emits an continuos noise is normal? Noise should issue only when running on battery and not with operation from 230v mains. I buy it because my Apc RS 800 is ko ! The 800 when run on 230 volt main supply do not emits any noise. The 800 emit noise only when work on battery.
Thank you
Message was edited by: fbassini
Hi fbassini, it sounds like this ups could be overloaded. If there too much equipment being plugged into this ups, it will emit a loud constant tone when on battery. I would suggest trying to remove a few devices and then see if the constant tone goes away when the UPS is operating on battery. Hope this helps.
