BE550G battery voltage low
Showing results forΒ
Did you mean:Β
  • BE550G battery voltage low
2150
125
DaveH52
Crewman DaveH52
Crewman
Posted: β€Ž2025-05-24 08:56 PM
1367
My BE550G is not fully charging its battery. The charging voltage is only 12.5V. My other UPSs (BE750G) have battery charging voltage of 12.7V. Is there a simple adjustment inside the unit that I can use to set the voltage?
I found a schematic and I think this is the circuit that controls the charging voltage by adjusting VR1.  I'm a retired EE and have plenty of meters and scopes and stuff, and I'm not afraid to open it up and poke around, but I thought I'd find out if others have run into this problem first.
  • Home & Office - UPS & Software
Replies 7
Kirk
Posted: β€Ž2025-05-26 02:52 AM
1352
How was the battery voltage taken?!?
Based on the reading you have provided it would seem it was taken while the battery was disconnected from the system.
As the float voltage would be 13.5 ~ 13.8 VDC. While equalize charging the input voltage would be 14.4 ~ 15.XX VDC.
Questions Ask . . . πŸ‘
DaveH52
Crewman DaveH52
Crewman
Posted: β€Ž2025-05-26 08:59 PM
In response to Teken
1333
Teken thanks for replying.
That was the charging voltage with the battery connected and measured with a Fluke 87 DMM. To make matters even worse, I had another battery that had been charged to 13.7V. When I installed it into the BE550G, the serial app said it was 13.7V which is what I expected. What I did not expect was that a day later, it said 13.5V. I have another BE550G, and I tried the same experiment. It started at 13.7V, and a day later it was at 13.5V. I opened one of the BE550Gs to see if there was a voltage adjustment, but I could not find anything to adjust anywhere inside. Apparently, it's set in the UPS firmware, and I have not seen any firmware files anywhere. So, I'm seriously considering trying to sneak a small surface mount regulator board inside both units that I can set to 13.8V so the battery takes more charge. Unfortunately, empty space inside will be a challenge.
Kirk
Posted: β€Ž2025-05-27 03:28 AM
In response to DaveH52
1318
A 13.5 VDC float voltage is perfectly fine as this is within the battery makers charging specifications.
Any voltage that is above 12.80 ~ 12.90 VDC will fully charge and saturate a battery cell.
Being on the lower floating threshold has the benefit of extending the battery service life as it will not boil out the electrolyte.
DaveH52
Crewman DaveH52
Crewman
Posted: β€Ž2025-05-27 11:29 AM
1299
That does make some sense, at least about the electrolyte. However, it seems that the BE550G tells me that I've got a considerably longer run-time when the battery has been charged at 3.7V, as opposed to 3.5V. Perhaps I'm just so used to automotive batteries that charge at 13.8V
Kirk
Posted: β€Ž2025-05-28 01:45 AM
1298
13.5 ~ 13.8 VDC is the Float voltage not the charging voltage.
The operational runtime seen  / displayed is reflective of the load, battery health, and temperature.
A 13.5 VDC Float charge has absolutely no impact whatsoever on the operational runtime.
DaveH52
Crewman DaveH52
Crewman
Posted: β€Ž2025-05-28 10:12 AM
1252
OK next issue.
One of my BE550Gs does not seem to be showing the % load.
What I've been doing is plugging another computer into a battery-backed outlet, waiting for Micro$oft and all the other start-up SW has settled down and until Task Manager says it's idling at about 1% CPU then telling my browser to reload the page, which also causes the APC software to update.
So this particular BE550G says that it has 475 minutes of runtime and that there is 0% load on it. Now I don't think an intel i7 cpu, spinning HDD, and everything else in that box is capable of running without drawing any power.
Do you know how the power consumption or % load is measured inside the BE550? Is there a torroid or other kind of current sense transformer in the BE550 that might have an open winding or a bad solder joint?
What I'd really like to get my hands on are schematics for the BE550G and the BE750G UPSs.
Again, thanks for putting up with me!
Kirk
Posted: β€Ž2025-05-29 03:25 AM
The current is measured either by a current transformer or IC. The operational runtime you see is simply an estimate based on some very crude firmware and software calculations.
This is part of the reason(s) why you will see unrealistic runtimes with / without connected loads on the outputs of the UPS.
Also keep in mind every UPS has a minimum load that must be presented to the system to even register a value.
Whether that value is reflective of actual reality comes down to components tolerances, design, and specifications of each unit.
As such the basics are to have in place to achieve the most accurate operational runtime displayed / calculated.
Load: Minimum 30% load connected to the systems outputs.
Battery (RBC): The average service life is 2-5 years based on usage, temperature, and environmental conditions. A weak battery will result in erratic performance and inaccurate runtime.
Battery Install Date: When the battery is replaced if the system supports the ability to update the installation date - do so. As this resets internal counters and adjusts internal tables that affect charging etc.
Battery Calibration: If supported this step is critical to complete so it will teach the system the current load, battery health, and allow it to more accurately reflect (display) the operational runtime of the system as a whole.
This procedure must be done when a new battery cartridge is installed with a minimum of 30% load attached. Once complete and the battery has been recharged to 100% SOC.
The displayed operational runtime will be relatively more accurate based on the minimum load stated by the manufacturer data sheet.
Β
