Posted: 2022-11-06 01:17 AM
Hi! my ups not function anymore. I tried to replace the battery but same problem. when I turn on the continues beep happened and no light blinking. and I tried also the battery working on my new ups. and put it on BE500R-PH but same problem. so I decided to open up and check what is the cause. but I saw no burned any component inside. I tried to replace LM324AN ic but same problem. I tried to checked all mosfet and all small transistor but all are good. I suspected the microcontroller pic16f716. my question is, If I bought new another pic16f716 is it need to program using pic programmer? or no need to program it, just solder it to the board? thanks in advance!
Posted: 2022-11-07 04:26 AM
Hi @waldopulanco,
Thank you for reaching out to the SE Community, my name is Jon and I will assist you with this query. Apologies for the inconvenience this has caused.
I personally haven't done replacing the internal components of our UPS and we always advise our customers to never open the UPS aside from the battery door.
I recommend that you reach out to our technical support team handling your country to see if there are authorized repair centers.
https://www.se.com/ww/en/work/support/country-selector/contact-us.jsp
