APC Power-Saving Back-UPS Pro 1000's event numbers on its front panel.
Select a Country
  • APC Power-Saving Back-UPS Pro 1000's event numbers on its front panel.
BillP Leader
2150
144
Techie_apc
Techie_apc
83
ant_apc
ant_apc
Contributor
Posted: ‎2021-06-29 06:11 AM . Last Modified: ‎2024-03-21 05:42 AM
14473
Hi.
I recently replaced my old UPS with an APC Power-Saving Back-UPS Pro 1000 (http://buy.apc.com/commerce/storefronts/tradeups/product.aspx?storefrontcode=apcetu&countrycode=US&t... ) on Friday. After a full weekend, I noticed its number said three events and my Windows 7 HPE was frozen at its login screen (no mouse and keyboard responses). Is there a way to figure out what these three numbers mean? I did not see any interesting errors in my updated 64-bit Windows 7 HPE (IE8).
Thank you in advance. 🙂
BillP Leader
Leader
Posted: ‎2021-06-29 06:12 AM . Last Modified: ‎2024-03-21 05:42 AM
That is correct Ant.
Replies 8
BillP Leader
Leader
Hi Ant,
The number of events that shows up on the LCD screen are the number of power disturbances that your UPS has detected. These disturbances can be any of the following: blackout, under/over voltage, total harmonic distortion, surge, spike, etc.
If you do have PowerChute Personal Edition installed and it is monitoring the UPS, this would give you more information on how many of these disturbances has been detected.
ant_apc
ant_apc
Contributor
JonPro wrote:
Hi Ant,
Ah OK, I will have to install it then later. I was hoping 64-bit W7 HPE already could do that. Is the provided CD the latest version, or is there a newer one online to skip over the CD? Also, does apcupsd from http://www.apcupsd.com/ detect and show these details too like PowerChute?
BillP Leader
Leader
Unfortunately, I am not familiar and have not used APCUPSD since this is a third party application which I do not support. With regards to PCPE, you can download the latest PCPE 3.0 from our download site. Make sure that you choose SFPCPE30 from the download link here - [PowerChute Personal Edition v3.0|http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=SFPCPE30&tab=Software]
Also here is the PCPE Compatibility Chart - [Click here|http://www.apcmedia.com/salestools/JNOE-7GSAQJ_R8_EN.pdf]
ant_apc
ant_apc
Contributor
That sucks. UPS should record all that information and have PC's softwares to read off their datas. 😞
ant_apc
ant_apc
Contributor
Thanks! I installed, but it didn't show me what the events were about. I attached its screen shot.
Also, my boss who got the same UPS when she ordered mine, said hers said one event. She sits right in front of me. Weird.
BillP Leader
Leader
Unfortunately the software would only record the events that it has detected after installation. With regards to your UPS, using the APC software I recommend that you check the current sensitivity settings and set it to a much more lower value. If the UPS is too sensitive, a slight change on the voltage or frequency can cause the UPS to switch to battery mode.
ant_apc
ant_apc
Contributor
So wait. Are you saying I have to leave my PC with this PowerChute (Display.exe and not PowerChute.exe program process) running to record all these upcoming events? So far, no new events recorded and still at 3 on UPS' panel.
BillP Leader
Leader
