Posted: 2021-06-29 06:12 AM . Last Modified: 2024-03-21 05:42 AM
Hello.
I have had this problem since 2008. I am going to assume the old house (from the late 1970s/70s) power setup is old and maybe not enough due to lots of power usage. Once in a while when I turn on my old 20" CRT TV from 1996, my APC Back-UPS RS 1500 will beep and think there is a power failure for about a couple seconds but there isn't one. I did notice my old lamp flicker. I also notice this across the hall when someone turns on his old Dell Optiplex PC.
Is my UPS too sensitive to my old house's power? I did record the event logs on my old Debian/Linux box (note all the quick power failures and returns):
$ cat /var/log/apcupsd.events
2010-09-21 06:37:09 -0700 apcupsd exiting, signal 15
2010-09-21 06:37:09 -0700 apcupsd shutdown succeeded
2010-09-21 06:38:25 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-09-26 13:28:55 -0700 Power failure.
2010-09-26 13:28:57 -0700 Power is back. UPS running on mains.
2010-09-28 18:22:15 -0700 Power failure.
2010-09-28 18:22:17 -0700 Power is back. UPS running on mains.
2010-10-01 07:58:19 -0700 Power failure.
2010-10-01 07:58:21 -0700 Power is back. UPS running on mains.
2010-10-01 11:00:18 -0700 Power failure.
2010-10-01 11:00:20 -0700 Power is back. UPS running on mains.
2010-10-01 21:46:01 -0700 apcupsd exiting, signal 15
2010-10-01 21:46:02 -0700 apcupsd shutdown succeeded
2010-10-01 21:27:06 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-10-01 21:44:14 -0700 apcupsd exiting, signal 15
2010-10-01 21:44:14 -0700 apcupsd shutdown succeeded
2010-10-01 21:45:09 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-10-01 21:47:53 -0700 apcupsd exiting, signal 15
2010-10-01 21:47:53 -0700 apcupsd shutdown succeeded
2010-10-01 21:48:47 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-10-01 21:54:01 -0700 apcupsd exiting, signal 15
2010-10-01 21:54:01 -0700 apcupsd shutdown succeeded
2010-10-01 21:56:43 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-10-01 23:28:19 -0700 apcupsd exiting, signal 15
2010-10-01 23:28:19 -0700 apcupsd shutdown succeeded
2010-10-01 23:29:14 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-10-01 23:32:52 -0700 apcupsd exiting, signal 15
2010-10-01 23:32:52 -0700 apcupsd shutdown succeeded
2010-10-01 23:33:46 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-10-01 23:40:33 -0700 apcupsd exiting, signal 15
2010-10-01 23:40:33 -0700 apcupsd shutdown succeeded
2010-10-01 23:41:22 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-10-01 23:44:24 -0700 apcupsd exiting, signal 15
2010-10-01 23:44:24 -0700 apcupsd shutdown succeeded
2010-10-01 23:45:46 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-10-01 23:46:43 -0700 apcupsd exiting, signal 15
2010-10-01 23:46:43 -0700 apcupsd shutdown succeeded
2010-10-01 23:51:52 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-10-06 20:50:33 -0700 Power failure.
2010-10-06 20:50:36 -0700 Power is back. UPS running on mains.
2010-10-17 20:50:52 -0700 Power failure.
2010-10-17 20:50:55 -0700 Power is back. UPS running on mains.
2010-10-18 07:28:38 -0700 apcupsd exiting, signal 15
2010-10-18 07:28:38 -0700 apcupsd shutdown succeeded
2010-10-18 07:29:34 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-10-25 07:24:52 -0700 apcupsd exiting, signal 15
2010-10-25 07:24:52 -0700 apcupsd shutdown succeeded
2010-10-25 07:25:47 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-10-26 22:54:19 -0700 Power failure.
2010-10-26 22:54:21 -0700 Power is back. UPS running on mains.
2010-10-31 21:27:40 -0700 Power failure.
2010-10-31 21:27:43 -0700 Power is back. UPS running on mains.
2010-11-03 07:51:20 -0700 apcupsd exiting, signal 15
2010-11-03 07:51:20 -0700 apcupsd shutdown succeeded
2010-11-03 07:52:16 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-11-19 22:22:43 -0800 Power failure.
2010-11-19 22:22:45 -0800 Power is back. UPS running on mains.
2010-11-20 08:47:12 -0800 Power failure.
2010-11-20 08:47:15 -0800 Power is back. UPS running on mains.
2010-11-26 22:13:22 -0800 Power failure.
2010-11-26 22:13:25 -0800 Power is back. UPS running on mains.
2010-11-28 09:33:58 -0800 apcupsd exiting, signal 15
2010-11-28 09:33:58 -0800 apcupsd shutdown succeeded
2010-11-28 09:34:56 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-11-28 19:18:43 -0800 apcupsd exiting, signal 15
2010-11-28 19:18:43 -0800 apcupsd shutdown succeeded
2010-11-28 19:19:37 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-12-12 12:40:15 -0800 Power failure.
2010-12-12 12:40:18 -0800 Power is back. UPS running on mains.
2010-12-13 08:39:59 -0800 apcupsd exiting, signal 15
2010-12-13 08:39:59 -0800 apcupsd shutdown succeeded
2010-12-13 08:40:54 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-12-20 16:07:31 -0800 apcupsd exiting, signal 15
2010-12-20 16:07:31 -0800 apcupsd shutdown succeeded
2010-12-20 18:47:42 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-12-20 20:14:05 -0800 apcupsd exiting, signal 15
2010-12-20 20:14:05 -0800 apcupsd shutdown succeeded
2010-12-20 20:14:52 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-12-24 06:48:00 -0800 apcupsd exiting, signal 15
2010-12-24 06:48:00 -0800 apcupsd shutdown succeeded
2010-12-24 07:03:46 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-12-24 17:25:10 -0800 apcupsd exiting, signal 15
2010-12-24 17:25:10 -0800 apcupsd shutdown succeeded
2010-12-24 17:25:57 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-12-24 19:54:01 -0800 apcupsd exiting, signal 15
2010-12-24 19:54:01 -0800 apcupsd shutdown succeeded
2010-12-24 19:54:50 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-12-25 18:31:26 -0800 apcupsd exiting, signal 15
2010-12-25 18:31:26 -0800 apcupsd shutdown succeeded
2010-12-25 18:32:14 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-12-26 13:18:07 -0800 apcupsd exiting, signal 15
2010-12-26 13:18:07 -0800 apcupsd shutdown succeeded
2010-12-26 13:18:54 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2010-12-28 21:15:31 -0800 Power failure.
2010-12-28 21:15:32 -0800 Power is back. UPS running on mains.
2011-01-01 18:20:22 -0800 apcupsd exiting, signal 15
2011-01-01 18:39:42 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-01-08 19:20:12 -0800 Power failure.
2011-01-08 19:20:14 -0800 Power is back. UPS running on mains.
2011-01-15 10:51:06 -0800 apcupsd exiting, signal 15
2011-01-15 10:51:06 -0800 apcupsd shutdown succeeded
2011-01-15 10:51:57 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-01-24 04:32:59 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-01-24 06:03:02 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-01-24 07:24:46 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-01-24 07:26:37 -0800 apcupsd exiting, signal 15
2011-01-24 07:26:37 -0800 apcupsd shutdown succeeded
2011-01-24 07:29:39 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-01-26 01:31:39 -0800 Power failure.
2011-01-26 01:31:43 -0800 Power is back. UPS running on mains.
2011-01-26 01:31:55 -0800 Power failure.
2011-01-26 01:31:58 -0800 Power is back. UPS running on mains.
2011-01-26 01:32:36 -0800 Power failure.
2011-01-26 01:32:39 -0800 Power is back. UPS running on mains.
2011-01-26 03:40:20 -0800 Power failure.
2011-01-26 03:40:23 -0800 Power is back. UPS running on mains.
2011-02-18 20:17:18 -0800 Power failure.
2011-02-18 20:17:21 -0800 Power is back. UPS running on mains.
2011-02-21 12:20:55 -0800 apcupsd exiting, signal 15
2011-02-21 12:20:55 -0800 apcupsd shutdown succeeded
2011-02-21 12:21:45 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-02-21 14:17:23 -0800 apcupsd exiting, signal 15
2011-02-21 14:17:23 -0800 apcupsd shutdown succeeded
2011-02-21 14:21:49 -0800 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-02-22 21:57:42 -0800 Power failure.
2011-02-22 21:57:44 -0800 Power is back. UPS running on mains.
2011-03-07 22:37:26 -0800 Power failure.
2011-03-07 22:37:29 -0800 Power is back. UPS running on mains.
2011-03-16 22:25:06 -0700 Power failure.
2011-03-16 22:25:09 -0700 Power is back. UPS running on mains.
2011-03-20 08:55:51 -0700 apcupsd exiting, signal 15
2011-03-20 08:55:51 -0700 apcupsd shutdown succeeded
2011-03-20 08:56:48 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-04-02 22:02:27 -0700 Power failure.
2011-04-02 22:02:29 -0700 Power is back. UPS running on mains.
2011-04-11 18:56:24 -0700 apcupsd exiting, signal 15
2011-04-11 18:56:24 -0700 apcupsd shutdown succeeded
2011-04-11 18:57:24 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-04-20 00:16:45 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-04-20 00:30:32 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-05-02 10:20:57 -0700 Power failure.
2011-05-02 10:20:59 -0700 Power is back. UPS running on mains.
2011-05-06 17:23:00 -0700 apcupsd exiting, signal 15
2011-05-06 17:23:00 -0700 apcupsd shutdown succeeded
2011-05-06 17:24:52 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-05-08 21:08:42 -0700 Power failure.
2011-05-08 21:08:44 -0700 Power is back. UPS running on mains.
2011-05-13 07:33:04 -0700 Power failure.
2011-05-13 07:33:10 -0700 Running on UPS batteries.
2011-05-13 07:33:23 -0700 Reached remaining time percentage limit on batteries.
2011-05-13 07:33:23 -0700 Initiating system shutdown!
2011-05-13 07:33:23 -0700 User logins prohibited
2011-05-13 07:34:56 -0700 apcupsd exiting, signal 15
2011-05-13 07:34:56 -0700 apcupsd shutdown succeeded
2011-05-13 07:40:28 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-05-25 19:21:02 -0700 apcupsd exiting, signal 15
2011-05-25 19:21:02 -0700 apcupsd shutdown succeeded
2011-05-25 20:37:45 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
2011-06-08 21:40:24 -0700 Power failure.
2011-06-08 21:40:26 -0700 Power is back. UPS running on mains.
2011-06-14 20:43:34 -0700 apcupsd exiting, signal 15
2011-06-14 20:43:35 -0700 apcupsd shutdown succeeded
2011-06-14 20:44:37 -0700 apcupsd 3.14.8 (16 January 2010) debian startup succeeded
$ /sbin/apcaccess
APC : 001,037,0905
DATE : 2011-06-21 11:00:09 -0700
HOSTNAME : FooBar
VERSION : 3.14.8 (16 January 2010) debian
UPSNAME : FooBar
CABLE : USB Cable
MODEL : Back-UPS RS 1500
UPSMODE : Stand Alone
STARTTIME: 2011-06-14 20:44:35 -0700
STATUS : ONLINE
LINEV : 116.0 Volts
LOADPCT : 17.0 Percent Load Capacity
BCHARGE : 100.0 Percent
TIMELEFT : 50.6 Minutes
MBATTCHG : 5 Percent
MINTIMEL : 3 Minutes
MAXTIME : 0 Seconds
SENSE : High
LOTRANS : 097.0 Volts
HITRANS : 138.0 Volts
ALARMDEL : Always
BATTV : 26.9 Volts
LASTXFER : Low line voltage
NUMXFERS : 0
TONBATT : 0 seconds
CUMONBATT: 0 seconds
XOFFBATT : N/A
SELFTEST : NO
STATFLAG : 0x07000008 Status Flag
MANDATE : 2005-03-16
SERIALNO : QB0512132444
BATTDATE : 2005-03-16
NOMINV : 120 Volts
NOMBATTV : 24.0 Volts
NOMPOWER : 865 Watts
FIRMWARE : 8.g8 .D USB FW:g8
APCMODEL : Back-UPS RS 1500
END APC : 2011-06-21 11:00:52 -0700
Thank you in advance. 🙂
Hello.
$ /sbin/apcaccess
APC : 001,037,0905
HOSTNAME : FooBar
UPSNAME : FooBar
CABLE : USB Cable
STATUS : ONLINE
LINEV : 116.0 Volts
MAXTIME : 0 Seconds
SENSE : High
ALARMDEL : Always
BATTV : 26.9 Volts
NUMXFERS : 0
TONBATT : 0 seconds
XOFFBATT : N/A
SELFTEST : NO
NOMINV : 120 Volts
I am not familiar with APCUPSD so I am not sure if it offers the capability to change the sensitivity and transfer voltages, but I am sure that APC PCPE would do it.
If the RS 1500 is a beige/white one, PCPE 3.0 would work. I haven't tried installing it on a virtual PC but you can try it. There is also a manual procedure to adjust the sensitivity via the On/Off switch. The instructions are listed on the Users Manual
Hello.
$ /sbin/apcaccess
APC : 001,037,0905
HOSTNAME : FooBar
UPSNAME : FooBar
CABLE : USB Cable
STATUS : ONLINE
LINEV : 116.0 Volts
MAXTIME : 0 Seconds
SENSE : High
ALARMDEL : Always
BATTV : 26.9 Volts
NUMXFERS : 0
TONBATT : 0 seconds
XOFFBATT : N/A
SELFTEST : NO
NOMINV : 120 Volts
