what is the input voltage tolerance acceptable range of UPS Model: SUVT
  • what is the input voltage tolerance acceptable range of UPS Model: SUVT
Posted: ‎2021-06-28 08:45 AM . Last Modified: ‎2024-03-17 11:50 PM
3428
Hello ,
I am getting frequent alerts as below mentioned .
Name     : APC SUVT 15KVA
Code: 0x0210
Informational - UPS: An input voltage or frequency problem no longer prevents switching to bypass mode.
after download Data log & filtering we found
UPS - B
Date
20-Aug-18
Time
9:06:17
Vmin1
220.6
Vmin2
205.7
Vmin3
226.3
91%
20-Aug-18
8:56:17
221.4
205.9
222.9
92%
20-Aug-18
8:46:17
222.5
208.3
221.9
94%
20-Aug-18
8:36:17
221.1
209
221.3
94%
20-Aug-18
8:26:17
221.2
205.3
222
92%
20-Aug-18
8:16:17
220.2
207.4
223.1
93%
20-Aug-18
8:06:17
221.4
205.5
224.5
92%
20-Aug-18
7:56:17
222.9
209.7
226.8
92%
20-Aug-18
7:46:17
225
212.4
226.6
94%
UPS – A
8/20/18
9:08:49
222.2
205
225.4
91%
8/20/18
8:58:49
220.7
206.3
222
93%
8/20/18
8:48:49
223.2
207.6
222.9
93%
8/20/18
8:38:49
221.1
208.3
222.1
94%
8/20/18
8:28:49
221.6
204.5
221
92%
8/20/18
8:18:49
222.2
207
224.7
92%
8/20/18
8:08:49
221.3
205.1
223.8
92%
8/20/18
7:58:49
223.5
209
223.8
93%
8/20/18
7:48:49
224.9
212
227.8
93%
by compare between phase1, phase2, phase3 the difference voltage is 6% - 9%.
what is the acceptable rage of UPS input voltage ? Less than 5%?
Please advice.
Posted: ‎2021-06-28 08:45 AM . Last Modified: ‎2024-03-17 11:49 PM
Dear All,
As attached file I have capture from my ups Model SUVT. The event log shown the calibration is start & completed, But I don't know who was do it or it was automatic start by UPS its self or it does by virus or else? please kindly advise.
Veasna.
Replies 4
Hi Veasna
This event also occurs not only for voltage fluctuations but also when there is interference and noise on the input waveform, which is most likely the cause here.
The logs are only giving you a 5 minute interval snapshot of the voltages as well, putting a power analyser on the utility power will give you a much more complete picture of what is going on.
Regards
Matt
Hi Matt,
Thanks for your answer.
I would like to attached file Data log & Event log
could you help analyze what is the root cause & issue?
Veasna.
Hi Veasna
At this point it would be best to call your local APC technical support on +855-23-964-311 or using this Contact Form , so it can be handled by agents who deal with the SUVT product.
Regards
Matt
Dear All,
Veasna.
