" power sys error -02000 " in APC UPS SRT5KLXI NEW
  • " power sys error -02000 " in APC UPS SRT5KLXI NEW
Posted: ‎2021-06-30 08:28 PM . Last Modified: ‎2024-03-07 12:26 AM
8998
Hello my APC UPS SRT5KLXI start wiht error code 02000 (power sys error -02000) i do everything and nothing yet.
here some clue and help logs.
Need help as possible as soon
Logs:
02/07/2017 15:05:19 Device UPS: The output power is turned off. 0x0114
02/07/2017 15:05:19 Device UPS: The output power is now turned on. 0x0113
02/07/2017 15:05:19 Device UPS: The graceful shutdown period has ended. 0x014F
02/07/2017 15:05:19 Device UPS: The power for switched outlet group 2, Outlet Group 2, is off. 0x0186
02/07/2017 15:05:19 Device UPS: The power for switched outlet group 1, Outlet Group 1, is off. 0x0186
02/07/2017 15:05:19 Device UPS: An inverter fault exists. 0x0165
02/07/2017 15:05:19 Device UPS: Restored the local network management interface-to-UPS communication. 0x0101
02/07/2017 15:05:10 System Network service started. IPv6 address FE80::2C0:B7FF:FEF6:74D7 assigned by link-local autoconfiguration. 0x0007
02/07/2017 15:05:02 System Network Interface restarted. 0x0002
02/07/2017 15:04:54 System Network Interface restarting. Configuration 0x0009
02/07/2017 15:04:54 System Configuration change. Boot mode. 0x0033
02/07/2017 14:57:53 Device UPS: The output power is turned off. 0x0114
02/07/2017 14:57:53 Device UPS: The output power is now turned on. 0x0113
02/07/2017 14:57:53 Device UPS: The graceful shutdown period has ended. 0x014F
02/07/2017 14:57:53 Device UPS: The power for switched outlet group 2, Outlet Group 2, is off. 0x0186
02/07/2017 14:57:53 Device UPS: The power for switched outlet group 1, Outlet Group 1, is off. 0x0186
02/07/2017 14:57:53 Device UPS: An inverter fault exists. 0x0165
02/07/2017 14:57:53 Device UPS: Restored the local network management interface-to-UPS communication. 0x0101
02/07/2017 14:57:43 System Network service started. IPv6 address FE80::2C0:B7FF:FEF6:74D7 assigned by link-local autoconfiguration. 0x0007
02/07/2017 14:57:25 System Network Interface coldstarted. 0x0001
02/07/2017 14:57:06 System Network Interface restarting. 0x0009
02/07/2017 14:57:02 System Network service started. IPv6 address FE80::2C0:B7FF:FEF6:74D7 assigned by link-local autoconfiguration. 0x0007
02/07/2017 14:56:44 System Network Interface coldstarted. 0x0001
02/07/2017 14:48:41 System Network service started. IPv6 address FE80::2C0:B7FF:FEF6:74D7 assigned by link-local autoconfiguration. 0x0007
02/07/2017 14:48:23 System Network Interface coldstarted. 0x0001
02/07/2017 14:46:33 Device UPS: The output power is turned off. 0x0114
02/07/2017 14:46:33 Device UPS: The graceful shutdown period has ended. 0x014F
02/07/2017 14:46:33 Device UPS: The power for switched outlet group 2, Outlet Group 2, is off. 0x0186
02/07/2017 14:46:32 Device UPS: The power for switched outlet group 1, Outlet Group 1, is off. 0x0186
02/07/2017 14:46:32 Device UPS: An inverter fault exists. 0x0165
02/07/2017 14:46:32 Device UPS: Bypass not in range ; low voltage. 0x020F
02/07/2017 14:46:32 Device UPS: Restored the local network management interface-to-UPS communication. 0x0101
02/07/2017 14:46:22 System Network service started. IPv6 address FE80::2C0:B7FF:FEF6:74D7 assigned by link-local autoconfiguration. 0x0007
02/07/2017 14:46:04 System Network Interface coldstarted. 0x0001
  • 02000
  • error
  • power
  • srt5klxi
Hi Juan,
For this issue, we would recommend you call in to our technical support line so we can provide you with the best troubleshooting steps.
Thank so much, i'll contact your technical support for assistance.
HI ;TO WHOM IT MAY CONCERN;  I ALSO HAVE A SRT5KXLI UPS  WITH A 02000 POWER SYSTEM ERROR EVENT LOG INVERTER HARDWARE CKT EVENT CODE 107   WILL APPRECIATE ASSISTANCE
THX BRIAN
BUENOS DIAS JUAN, le consulto si reparò el equipo con ese còdigo de error 02000?? yo tengo el mismo problema con un equipo RT 6000xkli
saludos
Posted: ‎2021-06-30 08:29 PM . Last Modified: ‎2024-03-07 12:26 AM
Hi Edgardo
Could you contact your local Customer Care Team ( +08104447246) about this issue and they will look after you
Regards
Matt
SO WHEN AN ERROR 02000 AND INTERNAL RBC DISCONNECTED....IS IT HARDWARE OR SOFTWARE COZ IM A TECHNICIAN KINDLY HELP......
8998
please told me if you solve this problem ? i have the same problem And i want solve it
if you solve this problem can you help me to solve it
Replies 15
Hi Juan,
THX BRIAN
saludos
Hi Edgardo
Regards
Matt
GRACIAS, pero al ser un foro ...esperaba una respuesta mas expeditiva y no caer en el servicio tècnico, tal vez la soluciòn la puede llevar a cabo nuestro personal tècnico interno.
Hi Edgardo -
We typically answer basic troubleshooting and configuration questions to the best of our ability. Issues that require in depth troubleshooting or hardware replacement are best handled by our local technical support teams.
Liam
JUAN , buenos dìas. te consulto si te pusiste en contacto con el soporte tècnico tal como te lo sugirieron? si es asi, el equipo funciono?
yo tengo el mismo error con un equipo de 6kva.
aguardo tu respuesta, saludos
KINDLY ANSWER ME IN ENGLISH IM IN KENYA PLEASE ITS 6KVA
Anthony, just ask another user, JUAN, if he could solve it.
8999
Posted: ‎2021-06-30 08:29 PM . Last Modified: ‎2024-03-07 12:25 AM
I NEVER SUCCEEDED KINDLY
Joseph2
Joseph2 Cadet
Cadet
Posted: ‎2022-02-15 08:05 PM
In response to BillP
How do I solve the power system error for apc srt 5kva
