low Runtime Remaining Smart-UPS RT 8000 XL
  • low Runtime Remaining Smart-UPS RT 8000 XL
Posted: ‎2021-06-30 08:15 PM . Last Modified: ‎2024-03-07 12:30 AM
3342
Hi There
We have a low run time remaining of  11min
Here are the other value given :
The load of the server isn't much about 16% but I only have   11  remaining which I think should be a lot more then that ??
I did a calibration test but still the remaining minutes are still the same can you help?
thanks
  • 8000
  • rt
  • smart-ups
  • xl
Posted: ‎2021-06-30 08:16 PM . Last Modified: ‎2024-03-07 12:29 AM
I just called scheider electric and they are gonne send me new battery ( again) those i received might be a bad set so once i received it i will gave them 24h charges and let you know if that fix my problem, thanks for the help
Replies 10
Hello Sir,
Good day to you. There are few reason why you will encounter such problem. You can reference to this article:
http://www.apc.com/us/en/faqs/FA157077/.
thanks for the reply
so you say if
Light load accuracy- The estimated runtime values quoted on the web are based on an algorithm which tends to be less accurate for light loads and long runtime applications.
my load is too loght  the ups will be less accurate ? so i should put some more  load to it ??
That would be one thing we you can try. Also have you ever replaced the batteries of the UPS? If you did, when was the last time?
Posted: ‎2021-06-30 08:16 PM . Last Modified: ‎2024-03-07 12:30 AM
I just try to add some more loads but the minutes are decreasing to 6   min !!!
I change the battery in 2012-06-01
I have ordered a new sets of battery wich i change and still i have 11 min left with 16% load , can you help please ????
can anybody help please ????
Janeway
Did you perform a runtime calibration on the new battery?
After the battery has charged for 8 hours, I would unplug the UPS and see how long it runs your load. We'll call that "actual runtime." Then let it recharge and compare the actual runtime with the new estimate. I would also try comparing with the advertised runtime for the SRT8000XL, but I don't see the specs on APC's website anymore.
yes i did full calibration and self test with the new battery  still with the load at 20% i have 5 min left
Janeway
Alright. It'll be interesting to see how that 5 minute estimate compares to the actual runtime.
You might also want to inspect the battery for any serial numbers that could indicate date of manufacture.
Also, if the replacement is a genuine APC battery, you could contact APC's tech support here:
http://www.apc.com/us/en/support/contact-us/
