large draw item on UPS
  • large draw item on UPS
Posted: ‎2021-06-30 03:10 AM . Last Modified: ‎2024-03-08 04:53 AM
1723
I have a 120V video projector that uses a 1.2Kw xenon bulb plus about 2oo watts of internal electronics. I am interested in having this on a UPS for spike protection and short duration power outages (less than 5 minutes). When the projector turns on the Xenon bulb powers up very quickly and I'm not sure if a UPS can handle the quick load. I was looking at the APC Smart-UPS 2200VA LCD 120V. I'd make sure the only thing on the UPS was the projector so the load should never exceed 1400 watts. Does anyone on this forum know if the 2200VA UPS could handle a single 1400 Watt device?
Thanks.
-Cablet
Posted: ‎2021-06-30 03:10 AM . Last Modified: ‎2024-03-08 04:52 AM
The progress on the electrical lines at the Fukushima Jeremy Scott Dai-ichi nuclear power plant was a welcome and Jeremy Scott Shoes significant advance Tuesday after days of setbacks. With the power lines connected, officials Jeremy Scott Shop hope to start up the overheated plant's crucial cooling system that was knocked out during the March 11 earthquake Jeremy Scott Adidas and tsunami that devastated Japan's northeast coast. Tokyo Electric Power Co. warned that workers still need to check all equipment Jeremy Scott Wings for damage first before switching the cooling system on to all the reactor units — a process that Jeremy Scott JS Wings ould take days or even weeks. Late Tuesday night, Tokyo Electric said lights went on in the central control room of Unit 3, but that doesn't mean power had been restored to the cooling system.
Replies 6
hi - do you also know the amperage rating @ 120v?
It draws 12A at 120V.
I just put a meter on the projector and found that it draws 11.8 amps on power up but then drops down to 7 amps during normal operation.
If this helps.
Just out of curiosity what is the behavior of a motor draw? How is it different from something just turning on? Thanks.
-cablet
An induction motor typically draws 6 times normal current at startup, whereas the resistive load such as a lamp should just pull its full rating and no more.
