Posted: 2021-06-25 11:07 PM . Last Modified: 2024-03-19 03:21 AM
hi guys,
i just want to know what tools to use and how to use them when checking for a bad ups battery.
thank you in advance!
thanks for the tips matt. and oh i have a 12v battery and measured it using a digital meter the result is 12.47V based on your answer its a good battery, but when i installed it in my ups it gives out a constant tone along with the on line led and replace battery led alternating.
Hi
There are many things that can indicate a battery is bad
One of the simplest things you can do with a multimeter set to VDC is measure the voltage across the terminals, if for instance the battery is a 12v battery if it was below ~9.6v it would be considered bad.
A battery might show a good voltage when it isn't connected in circuit so it is worth also measuring when it is connected as well.
It is also worth doing a run time test as even if all the above is ok you might find that you get a short run time when the battery is actually in use.
Regards
Matt
