apcupsd and SMC1500I
  • apcupsd and SMC1500I
Posted: ‎2021-06-28 10:38 PM . Last Modified: ‎2024-03-14 04:14 AM
2981
Hello!
apcupsd support SMC1500I?
thank you
  • apcupsd
  • smc1500i
Posted: ‎2021-06-28 10:39 PM . Last Modified: ‎2024-03-14 04:14 AM
I will buy SMC1500I for working with APCUPSD.
Thank you very much
Replies 10
APCUPSD supports the SMC attached via USB. The information displayed is the same as a SMT or SMX Smart-UPS.
When an electric current is turned off, APCUPSD normally shut down the computer (using the connection via usb to SMC1500I)?
If you configure the software to do so, yes. Below are the available configurable parameters. If you have other question concerning APCUPSD you should post to APCUPSD E-mail list.
# ======== Configuration parameters used during power failures ==========
# The ONBATTERYDELAY is the time in seconds from when a power failure
#   is detected until we react to it with an onbattery event.
#   This means that, apccontrol will be called with the powerout argument
#   immediately when a power failure is detected.  However, the
#   onbattery argument is passed to apccontrol only after the
#   ONBATTERYDELAY time.  If you don't want to be annoyed by short
#   powerfailures, make sure that apccontrol powerout does nothing
#   i.e. comment out the wall.
ONBATTERYDELAY 6
# Note: BATTERYLEVEL, MINUTES, and TIMEOUT work in conjunction, so
# the first that occurs will cause the initation of a shutdown.
# If during a power failure, the remaining battery percentage
# (as reported by the UPS) is below or equal to BATTERYLEVEL,
# apcupsd will initiate a system shutdown.
BATTERYLEVEL 5
# If during a power failure, the remaining runtime in minutes
# (as calculated internally by the UPS) is below or equal to MINUTES,
# apcupsd, will initiate a system shutdown.
MINUTES 3
# If during a power failure, the UPS has run on batteries for TIMEOUT
# many seconds or longer, apcupsd will initiate a system shutdown.
# A value of 0 disables this timer.
#  Note, if you have a Smart UPS, you will most likely want to disable
#    this timer by setting it to zero. That way, you UPS will continue
#    on batteries until either the % charge remaing drops to or below BATTERYLEVEL,
#    or the remaining battery runtime drops to or below MINUTES.  Of course,
#    if you are testing, setting this to 60 causes a quick system shutdown
#    if you pull the power plug.
#  If you have an older dumb UPS, you will want to set this to less than
#    the time you know you can run on batteries.
TIMEOUT 0
#  Time in seconds between annoying users to signoff prior to
#  system shutdown. 0 disables.
ANNOY 300
# Initial delay after power failure before warning users to get
# off the system.
ANNOYDELAY 60
# The condition which determines when users are prevented from
# logging in during a power failure.
# NOLOGON [ disable | timeout | percent | minutes | always ]
NOLOGON disable
# If KILLDELAY is non-zero, apcupsd will continue running after a
# shutdown has been requested, and after the specified time in
# seconds attempt to kill the power. This is for use on systems
# where apcupsd cannot regain control after a shutdown.
# KILLDELAY   0 disables
KILLDELAY 0
1. Do I understand correctly that in this case will be applied protocol MODBUS?
2. All of this information (SMC1500I + APCUPSD) also applies to the SMT1500?
Modbus in not available with SMC. Modbus is available with SMT1500 that have firmware 9.0 and above.
Kbase FA175911 discusses SMTs and Modbus.
What protocol is used for exchanging SMC1500I + APCUPSD ?
The Back-UPS using standard USB to HID power device protocol. The information is available at this link http://www.usb.org/developers/hidpage/pdcv10.pdf
I use the operating system CentOS 6.6.
Do I understand correctly:
To fully support APCUPSD, I need to buy a model SMT1500I?
This model will provide a graceful shutdown and monitoring of critical parameters in the program APCUPSD?
APCUPSD supports the SMC attached via USB. The software can be configured to power down CentOS in the event of a power failure.
Here is a list of the date points APCUPSD will display
Thank you very much
